KB89924
Published: November 2, 2021
Some analog output channels do not return a value of QNAN when a quality code is present
Firmware for the following:
- GRV-EPIC-PR1
- GRV-EPIC-PR2
All versions prior to 3.3.0
3.3.0
For analog output modules, the channels do not display QNAN when a quality code is present.
This issue can be seen more clearly when you are using PAC Control: in the I/O Unit inspect window, the XVAL correctly shows 1.#QNAN
; however, the I/O Channel inspect window shows the last written value for the XVAL, which is incorrect. Both inspect windows should show the same value: 1.#QNAN
