KB89919
Published: October 28, 2021
groov View may not start when OPC UA tags are inputs to Computed Tags
  • GRV-EPIC-PR1, GRV-EPIC-PR2
  • GROOV-AT1, GROOV-AT1-SNAP
  • GRV-EPIC-PR1, GRV-EPIC-PR2: 3.2.0 to 3.2.2
  • All other products: R4.3a to R4.3d
  • GRV-EPIC-PR1, GRV-EPIC-PR2: 3.3.0
  • All other products: R4.3e
If your groov View project contains Computed Tags that use OPC UA tags for input, after restarting groov View, you may observe the following:
  • On groov Server for Windows, the service does not start and when you try to reach the groov View web page, the browser displays its general "Unavailable" web page.
  • On groov EPICs, the browser displays the "502 Bad Gateway" message.
Do not use OPC UA tags as inputs to Computed Tags.
