KB89909
Published: September 22, 2022
Get & Restart pulse measurement commands may not restart active pulses
Firmware for the following:
- GRV-EPIC-PR1
- GRV-EPIC-PR2
All versions prior to 3.3.3
3.3.3
If an on- or off-pulse measurement is in progress on a groov I/O module, the Get & Restart pulse measurement commands get the current value but may not restart the measurement; with this issue, the value does not clear and the input continues its measurement.
Do the following:
- For on-pulse measurements: Verify that the on-pulse measurement finished by running the Get On-Pulse Measurement Complete Status command before running the Get & Restart On-Pulse Measurement command.
- For off-pulses measurements: Verify that the off-pulse measurement finished by running the Get Off-Pulse Measurement Complete Status command before running the Get & Restart Off-Pulse Measurement command.
