KB89904
Published: November 2, 2021
MQTT string payloads missing part number; hardware date code only
- GRV-EPIC-PR1
- GRV-EPIC-PR2
groov RIOs:
- GRV-R7-MM1001-10
- GRV-R7-MM2001-10
groov EPICs: 2.0.0 to 3.2.2
groov RIOs: 2.0.0 through current
groov EPICs: 3.3.0
When running MQTT with string payloads, the part number tag may be missing the part number. It may only have the hardware date code.
