KB89902
Published: March 9, 2022
Using a value of zero with the "Set Year" command sets the controller to a date in 2136
Firmware for the following:
  • SNAP-PAC-S2, SNAP-PAC-S2-W
  • SoftPAC
All versions prior to R10.4d
R10.4d
In PAC Control, the Set Year command should only accept values from 1 to 99.  If a value of zero is used, it should be ignored; instead, it sets the year to 2136.
Use the Synchronize Clock SNTP command to set the controller's clock.
