KB89878
Published: October 28, 2021
Auto Navigator gadget allows write-only tags to be assigned to it
- GRV-EPIC-PR1, GRV-EPIC-PR2
- GROOV-AT1, GROOV-AT1-SNAP
- GRV-EPIC-PR1, GRV-EPIC-PR2: 2.0.0 to 3.2.2
- All other products: R4.2a to R4.3d
- GRV-EPIC-PR1, GRV-EPIC-PR2: 3.3.0
- All other products: R4.3e
In groov View Build mode, when you assign a tag to or update a tag on an Auto Navigator gadget, it should not allow you to select write-only tags. With this issue, groov View allows the assignment or change.
Do not assign write-only tags to Auto Navigator gadgets.
