KB89876
Published: August 17, 2021
groov EPIC processor may become unresponsive
- GRV-EPIC-PR1
- GRV-EPIC-PR2
May also affect firmware for the following products:
- GRV-R7-MM1001-10, GRV-R7-MM2001-10
- GROOV-AT1, GROOV-AT1-SNAP
groov EPICs: All versions prior to 3.2.2
Other products: All versions
groov EPICs: 3.2.2
In rare instances, the groov EPIC processor may become unresponsive. You may see any of the following:
- Module status LED on all modules turns red
- Touch screen becomes unresponsive
- No Ethernet communication
- RAM usage steadily increases (indicating a memory leak)
Monitor RAM usage and restart the groov EPIC processor if available RAM falls below 64 MB. You can create a Node-RED flow to monitor RAM usage and restart the groov EPIC processor when it gets too high. To learn the basics of creating Node-RED flows, see "Developing and Deplying Node-RED Flows" in the groov EPIC User's Guide (form 2267).
