KB89826
Published: August 17, 2021
groov View hangs due to lag in computed tags
- GRV-EPIC-PR1, GRV-EPIC-PR2
- GROOV-AT1, GROOV-AT1-SNAP
GRV-EPIC-PR1, GRV-EPIC-PR2: 3.0.0 to 3.2.1
All other products: groov View 4.3a to 4.3c
GRV-EPIC-PR1, GRV-EPIC-PR2: 3.2.2
All other products: groov View 4.3d
You may see the values of computed tags lag significantly behind real-time; for example, the computed value reflects input received minutes to hours earlier. Sustained high CPU usage by another process on the groov device (for example, Ignition Edge on a GRV-EPIC-PR1) will likely cause this issue. Eventually, groov View may stop responding.
Try the following options:
- Use fewer computed tags.
- Move processes with high CPU usage to another groov device or system.
- Look at ways to reduce CPU usage.
