KB89800
Published: July 8, 2021
Local I/O does not work after restart of EPIC with simple or serial modules on chassis
Opto 22 Library Package for CODESYS Development System
2.0.0.0 to current (may affect previous versions)
Under the following circumstances, if you restart the groov EPIC, the inputs on the local chassis will not work and the outputs may not work:
  • In your CODESYS application, your groov EPIC is local I/O.
  • Serial or any of the following modules are mounted on the groov EPIC chassis:
    • GRV-OACS-12
    • GRV-OACIS-12
    • GRV-ODCIS-12
    • GRV-OMRIS-8
    • GRV-IACS-24
    • GRV-IACIS-12
    • GRV-IACDCTTLS-24
    • GRV-IACHVS-24
    • GRV-IACIHVS-12
    • GRV-IDCIS-12
    • GRV-IDCS-24
    • GRV-IVIRMS-10
