KB89711
Published: June 15, 2021
System update fails: "Failed to import gpg certificate. The system clock may be too far in the past. Update the system clock."
Firmware for the following groov EPIC processors:
- GRV-EPIC-PR1
- GRV-EPIC-PR2
groov RIO modules:
- GRV-R7-MM1001-10
- GRV-R7-MM2001-10
For listed groov EPICs: All versions prior to 3.2.1For listed groov RIOs: All versions
For listed groov EPICs: 3.2.1
Updating system firmware on groov EPIC or groov RIO may fail with the message "Failed to import gpg certificate. The system clock may be too far in the past. Update the system clock."
