KB89695
Published: September 8, 2021
PAC Control: SNAP-AOD-29 shows incorrect units and values for Full Range
  • PAC Control Basic
  • PAC Control Professional
R10.2e to R10.3c (may affect earlier versions)
R10.4a
In PAC Control Config mode, if the I/O unit’s Temperature configuration is set to Fahrenheit, then the Edit a Point dialog box for points on SNAP-AOD-29 or SNAP-AOD-29-HFi modules incorrectly lists temperature units and values in the Full Range section. It should list Percent for the Units Field, 0 for Lower, and 100 for Upper.
If possible, change the setting on the I/O Unit to Celsius:
  1. Right click on the I/O unit name.
  2. Click Modify.
  3. In the Device Options section, click Celsius.
  4. Click OK to save the changes.
