KB89679
Published: May 3, 2021
Remote I/O may start with a timeout error
Library Package for CODESYS Development System
2.0.1.1 (may affect previous versions)
2.0.2.0
In CODESYS Development System, when you download and run your application, remote I/O will often start off with a spurious and benign timeout error. You may see a red exclamation mark over the green "connected" icon next to the name of the remote I/O unit. When you check diagnostic messages, you may see Communication timeout [missed incoming stream]. You can ignore this error.
