KB89676
Published: June 15, 2021
Modbus/TCP transactions may return incorrect exception code
Firmware for the following groov EPIC processors:
- GRV-EPIC-PR1
- GRV-EPIC-PR2
groov RIO modules:
- GRV-R7-MM1001-10
- GRV-R7-MM2001-10
For listed groov EPICs: All versions prior to 3.2.1For listed groov RIOs: All versions
For listed groov EPICs: 3.2.1
When a client sends messages to the Modbus/TCP server on groov EPIC, groov EPIC may return the wrong Modbus/TCP exception code.
