KB89675
Published: May 26, 2021
groov View bit writing doesn't work correctly for the upper 33 bits of a 64 bit integer
  • GRV-EPIC-PR1, GRV-EPIC-PR2
  • GROOV-AT1, GROOV-AT1-SNAP
GRV-EPIC-PR1: 3.1.0
All other products: R4.3a
GRV-EPIC-PR1: 3.2.0
All other products: R4.3b
When you're trying to write to the bits of a 64 bit integer, you find:
  • Bits 0 through 30 work correctly.
  • Writing to bit 31 or 63 sets bits 31 through 63 to the same value.
  • Writing a 1 to bits 32 through 62 sets bit X - 32 to 1. Writing a 0 does nothing.
