KB89674
Published: May 26, 2021
Can't select the last bit in an integer in the gadget properties panel bit selector
groov View running on:
  • GRV-EPIC-PR1, GRV-EPIC-PR2
  • GROOV-AT1, GROOV-AT1-SNAP
GRV-EPIC-PR1: 3.1.0 to current
All other products: R4.3a to current
In the Bit field in the gadget properties panel, you cannot select the last bit in an integer (bit 7, 15, 31, or 63, depending on the integer size). The input box turns red and won't accept the value. You can still open the full tag selector panel and select the bit there, but it will display as blank in the property panel.
Select a bit index in the tag selector, instead of the property panel.
