KB89673
Published: May 27, 2021
When bit 0 is selected in a gadget using bit picking, the automatic label fails to show "(bit 0)"
- GRV-EPIC-PR1, GRV-EPIC-PR2
- GROOV-AT1, GROOV-AT1-SNAP
GRV-EPIC-PR1: 3.1.0 to currentAll other products: R4.3a to current
When you use a bit-picked tag with a groov View gadget, the automatic label should display the bit you've chosen. For example, if you've selected bit 3, a gadget using a tag named "Int 64" should show "Int 64 (bit 3)" as the automatic label. With this issue, if you select bit 0, groov View doesn't add the bit index to the automatic label.
