KB89645
Published: June 8, 2021
Events won't load in Build mode if an event is using an invalid tag
- GRV-EPIC-PR1, GRV-EPIC-PR2
- GROOV-AT1, GROOV-AT1-SNAP
GRV-EPIC-PR1, GRV-EPIC-PR2: 3.1.0 to 3.4.3
All others: 4.3a to 4.3b
GRV-EPIC-PR1, GRV-EPIC-PR2: 3.4.4
All others: 4.3c
When you try to open the Configure Events panel in Build mode, the panel hangs with the "Loading Events" message sitting on top of it. This issue occurs when an event is configured with a missing tag, usually because a tag or device the event was relying on was deleted.
