KB89631
Published: April 16, 2021
Computed Tag Reports Error When Input is String Array Tag
groov View on the following:
  • GROOV-AT1, GROOV-AT1-SNAP
  • GRV-EPIC-PR1, GRV-EPIC-PR2
4.3a
4.3b
If you create a Computed Tag and set its source to a String Array tag, about 10 seconds after you view a page with a gadget using that tag, groov View displays a yellow triangle on the gadget. When you click the yellow triangle, groov View displays the message:
A value has not been received yet. groov is trying to connect to the controller or server.
