KB89626
Published: October 28, 2021
Array element field shows -1; can't erase with Backspace key
  • GRV-EPIC-PR1, GRV-EPIC-PR2
  • GROOV-AT1, GROOV-AT1-SNAP
  • GRV-EPIC-PR1, GRV-EPIC-PR2: 3.2.0 to 3.2.2
  • All other products: R4.3a to R4.3d
  • GRV-EPIC-PR1, GRV-EPIC-PR2: 3.3.0
  • All other products: R4.3e
If you try to remove text from the Array element field (in the Gadget properties panel) by pressing the backspace key, groov View sets the value to -1. The only way to clear the field is to select the text and overwrite it with new text.
Select all the text in that field, then type in the new text.
