KB89625
Published: April 16, 2021
Multiple Symptoms When Transmitting CAN Messages Using GRV-CCANI-2
Firmware for:
  • GRV-EPIC-PR1
GRV-EPIC-PR1 firmware 1.3.0 to current
GRV-CCANI-2: All versions
3.2.0
The following symptoms can occur after transmitting 12-20 messages via a GRV-CCANI-2 port into a misconfigured CAN bus:
  • Controller locks up
  • All groov module status LEDs (except for on/off status-only modules) turn RED.
  • I/O values are no longer updated
  • Touchscreen may stop responding
This problem can be prevented by making sure the CAN bus is correctly configured before transmitting from GRV-EPIC-PR1 using GRV-CCANI-2 (correctly terminated, at least one other working CAN device configured with the same data rate).
