KB89623
Published: March 9, 2022
PAC Control command "Is I/O Unit Ready?" may cause chart to freeze or host port to lose communication
  • SNAP-PAC-S2, SNAP-PAC-S2-W
R9.5f to R10.4c
R10.4d
When using the Is I/O Unit Ready? command on a serial I/O unit, the command may freeze:
  • In Debug mode, if the chart was in auto-step mode through the charts, the block with the instruction remains highlighted.
  • If you try to stop the strategy, host port communication is lost.
With either scenario, you have to cycle power to the controller to clear the issue.
