KB89546
Published: April 16, 2021
Cannot Browse Below "Resources" Folder on CODESYS OPC UA Server
Firmware for GRV-EPIC-PR1
2.0.0 to current
3.2.0
If you are using an OPC UA client and browsing through a CODESYS OPC UA server accessing a GRV-EPIC-PR1, you may not be able to expand branches below the Resources branch if the Application node is blank, like in the following tree:
DeviceSet/Opto22 ARM-Linux/Resources/<blank for Application node>/<other nodes>
In the above tree, any nodes at the level of the
<other nodes> branch may be inaccessible.
