KB89539
Published: April 16, 2021
Events Not Sending Email on GROOV-AR1 or GROOV-AT1
groov View running on:
  • GROOV-AT1, GROOV-AT1-SNAP
R4.3a
R4.3b
Events will not send email on the GROOV-AR1 or GROOV-AT1. If you look in the system logs, you will see a line like the following:
Feb 5, 2021 5:40:31 PM WARN com.opto22.groov.server.notification.EmailProcess - Failed
