KB89451
Published: January 22, 2021
GRV-IDCIFQ-12 on Remote EPIC May Not Retain Counter Feature After Restart
Opto 22 Library Package for CODESYS Development System
All versions
If your CODESYS application contains a remote GRV-EPIC-PR1 with a GRV-IDCIFQ-12 module that has some channels configured with the counter feature, the counter configuration on those channels may not be retained after a power cycle of the remote EPIC. If the configuration on those channels was done through another method (groov Manage or PAC Control) the counter configuration is retained after a power cycle of the remote EPIC.
Configure the counter features on those channels of the GRV-IDCIFQ-12 module using groov Manage.
