KB89435
Published: May 25, 2021
Firmware update fails for firmware files larger than ~2 GB
Firmware for:
- GRV-EPIC-PR1
- GRV-R7-MM1001-10
GRV-EPIC-PR1: All versions prior to 3.2.0 GRV-R7-MM1001-10: All versions prior to 3.2.0
GRV-EPIC-PR1: 3.2.0GRV-R7-MM1001-10: 3.2.0
You are more likely to see this issue if you try to install a firmware file that has "ignition8" in the filename without first installing the corresponding firmware file that has "ignition7" in the file name.
When you try to install a firmware file larger than approximately 2 GB, the update will fail and display the error message: The client failed to upload the system update file.
This issue is fixed starting in version 3.2.0; however, the fix isn't available until after 3.2.0 (or higher) has been successfully installed. Firmware files with “ignition7" in the filename are typically less than 2 GB in size, so first install an "ignition7" version of 3.2.0 (or higher) in order to get the fix. Then you can install a firmware version that is bigger than 2 GB. (Firmware files larger than 2 GB are typically files with "ignition8" in the file name.)
For example, to install the grv-epic-pr1-ignition8-3.2.0-b.44.field.bin file, first install the grv-epic-pr1-ignition7-3.2.0-b.44.field.bin file.
