KB89427
Published: December 8, 2020
Scaling for Analog Channels Reverts to Default Values
Firmware for GRV-EPIC-PR1
3.0.0
3.0.1
After any of the following, you may observe that scaling values on groov analog I/O channels are not restored; instead, default scaling values are loaded:
- Power up
- Restart using groov Manage > System > Restart
- Reset using the RESET button
- After upgrade to GRV-EPIC-PR1 firmware version 3.0.0, even if you enabled the "Back Up Settings" feature before the upgrade
If you are using a PAC Control strategy to configure I/O, starting the strategy will properly initialize the I/O channels. Otherwise, manually restore the scaling values using groov Manage.
