KB89418
Published: February 22, 2021
PAC Control: Some 32 Bits Commands Don't Copy Bit for Bit
Firmware for:
- SNAP-PAC-S2, SNAP-PAC-S2-W
- SNAP-PAC-R1, SNAP-PAC-R1-FM, SNAP-PAC-R1-W, SNAP-PAC-R1-B
- SoftPAC
Version R9.4a to R10.4b
R10.4c
The following PAC Control commands should move values between a 32-bit integer and 32-bit float, bit for bit, so if you move an integer to a float and back, the value of the integer should be unchanged:
- Float to Int32 Bits
- Int32 to Float Bits
- Move 32 Bits
With this issue, the value of the integer may be changed.
