KB89414
Published: February 22, 2021
Redundant System I/O may not be Re-enabled after I/O Power Cycle
Firmware for:
- SNAP-PAC-S2, SNAP-PAC-S2-W
Version R10.3c to R10.4b
R10.4c
If an I/O unit on a redundant system is power cycled or rebooted, you may not be able to re-enable communication to it—either manually via the PAC Control debugger or programmatically—resulting in "PUC Expected" errors in the controller’s message queue.
When the issue occurs, inspect the I/O unit through PAC Manager. It will then be possible to re-enable communication to the I/O unit.
