KB89405
Published: May 25, 2021
Digital input channel set for continuous frequency doesn't report 0 Hz when input stops toggling
Firmware for GRV-R7-MM1001-10
All versions prior to 3.2.0
3.2.0
If you configure channel 0 or 1 of GRV-R7-MM1001-10 as a digital input that measures frequency, the channel does not report 0 Hz when the input stops toggling; instead, the channel holds the last measured value.
Read and clear—at regular time intervals—the on-latch of the digital input channel that is measuring frequency. If the latch is not set, then the frequency is 0 Hz.
