KB89398
Published: December 9, 2020
Digital Output (Except Mechanical Relays) May Pulse On Briefly When Strategy Is Started
Firmware for GRV-R7-MM1001-10
All versions prior to 3.0.0
3.0.0
In groov Manage, when you change the signal type on channels 0-7 from a digital input to a digital output while live voltage is applied to the field connector that causes the input to report it's state as ON, the output will turn on briefly. You can see this while looking at the channel's LED indicators on your groov RIO: the input channel LED turns off and the output channel LED briefly flashes on when you save the digital output configuration.
