KB89386
Published: December 23, 2020
groov Serial Channels and Possibly I/O Unit Missing After Import
- PACCONTROLBAS (PAC Control Basic)
- PACCONTROLPRO (PAC Control Professional)
All versions prior to R10.3d
R10.3d
When you export a chart that contains references to groov serial channels and then import it into a new/different strategy, the serial channels are missing. If the I/O unit contains only groov serial modules, the I/O unit will also be missing.
