KB89350
Published: February 19, 2021
At Symbol (@) in Video Gadget URL May Prevent Images From Loading
groov View running on:
  • GROOV-AT1, GROOV-AT1-SNAP
  • GRV-EPIC-PR1
All versions prior to R4.3a
R4.3a
If you have a video gadget with the 'Use groov as a proxy' option checked and the gadget's URL contains an at symbol (@), the video proxy module in the groov View server may fail to load images.
For example, this works:
https://username:password@server.example.com/path/to/resource
But this doesn’t:
http://server.example.com/path/to/camera?user=user&password=p@ssword
Do one of the following:
  • Don't use the proxy option: double-click on the video gadget and then uncheck 'Use groov as a proxy' from the Video Gadget Properties window.
  • Provide the URL without the at (@) symbol, such as encoding it as a percent-escape code. The percent-escape code for @ is %40.
