KB89336
Published: April 21, 2021
Touchscreen stuck on power up progress screen
Firmware for GRV-EPIC-PR1
2.0.2 to 3.1.0 (may affect earlier versions)
3.2.0
In rare cases, after a power cycle, you may observe that the GRV-EPIC-PR1 touchscreen appears to be stuck on the screen that shows "groov EPIC" with the progress bar showing approximately 80% complete. This issue may also cause a unit to lock up while in operation. You may also observe any of the following:
  • STATUS LED is blinking green.
  • POWER LED is solid green.
  • The LEDs on the groov I/O modules may be red or blue.
  • No Ethernet communications: you cannot connect to the GRV-EPIC-PR1.
Power cycle the GRV-EPIC-PR1.
