KB89267
Published: February 19, 2021
Can't Switch to Build Mode When Using More Than One Percent (%) Symbol in Formatting String
groov View running on:
- GROOV-AT1, GROOV-AT1-SNAP
- GRV-EPIC-PR1
All versions prior to R4.3a
R4.3a
If your groov View project has any gadgets with a formatting string that has more than one percent (%) symbol, when you run the project in View mode, those gadgets will display an error and you won't be able to switch to Build mode. If you view the system logs, you'll see lines like this one:
01:49:06,801 ERROR [qtp22260990-449] c.a.g.l.c.Log - Too many percent/per mille characters in pattern "0.0%%"
