KB89210
Published: September 18, 2020
After power cycle, groov Manage REST API calls or Node-RED for groov I/O nodes may fail
GRV-R7-MM1001-10
2.0.0 to 2.0.1
2.0.2
After a power cycle or restart of a groov RIO, REST API calls to groov Manage or Node-RED flows with Node-RED for groov I/O nodes may fail. You may see the following in the log files (from groov Manage Home, click Info and Help > Logs):
- The Node-RED logs will show errors like:
[error] [groov-io-input:9d4cd717.813378] Status code 403. HTTP response error : 403
- The groov Manage logs will show many errors like:
[ERROR] AuthService - Could not find user
This can affect the following:
- On a groov RIO, Node-RED for groov I/O nodes accessing the local I/O channels.
- From another device, Node-RED for groov I/O nodes accessing the I/O on a groov RIO.
- Any client using the groov Manage REST API on a groov RIO.
Log in to groov Manage after a power cycle or restart.
