KB89205
Published: December 23, 2020
PAC Control Edit PID Loop Dialog Does Not Always Save Changes
- PACCONTROLBAS (PAC Control Basic)
- PACCONTROLPRO (PAC Control Professional)
R10.1 (may occur in earlier versions) to R10.3c
R10.3d
If you open the Edit PID dialog in Configure mode of PAC Control and use the keyboard to make changes to Input, Setpoint, and/or Output, then click OK , when you re-open the dialog, the changes are not retained. However, if you use the mouse or arrow keys to make selections in the drop-down menus, the changes are saved correctly.
Use mouse or arrow keys to make selections rather than typing them with the keyboard.
