KB89203
Published: August 21, 2020
Add Serial Channel and Add Analog Point dialog boxes show incorrect options in Type and Module fields for groov modules
PAC Control Basic
PAC Control Professional
R10.3b
R10.3c
In PAC Control, when adding points to groov modules, the Add Serial Channel and Add Analog Point dialog boxes show incorrect options in the Type and Module fields:
  • The Add Serial Channel dialog box shows some channel types that aren’t valid. The list should only show channel types that are valid for the selected module.
  • The Add Analog Point dialog box shows channel types for all groov analog modules. The list should only show channel types that are valid for the selected module.
