KB89200
Published: February 19, 2021
Only 32 Colors Available on LED Gadgets With Non-Boolean Tag Types
groov View running on:
- GROOV-AT1, GROOV-AT1-SNAP
- GRV-EPIC-PR1
R3.4a to R4.2c
R4.3a
When configuring color ranges on an LED gadget, if you select a Boolean tag, you can access the full palette of 56 colors. However, if you select any other tag type, you can only access 32 colors.
