KB89183
Published: November 4, 2020
PAC REST API May Time Out When Reading a Range of String Table Entries
Firmware for GRV-EPIC-PR1
1.0.0 to 2.0.2
3.0.0
When you use the readStringTable PAC REST API endpoint on a GRV-EPIC-PR1 (for example, https://<your-PR1-Hostname>/api/v1/device/strategy/tables/strings/strTable
), the request may time out. The more elements you're trying to read, the more likely the request will timeout.
If you know the average length of the strings, you can tune the batch size (by adjusting the value of the numElements
parameter) to avoid going over 1,218 bytes. Aim for no larger 1,100 characters total to provide room for length and status bytes.
