KB89178
Published: August 13, 2020
GRV-IMAI-8 Module Refreshing at Incorrect Rate
Firmware for GRV-IMAI-8
Discovered in 1.3c, may affect earlier versions
1.3d
With the Simple Moving Average (SMA) filter set to 1, the module is supposed to update its data at a rate of 11 ms. However, the module is refreshing its data approximately every 200 ms.
