KB89169
Published: August 31, 2020
Square Wave A (1 sec on/off) on Data Simulator does not turn on
groov View running on:
- GROOV-AT1, GROOV-AT1-SNAP
- GRV-EPIC-PR1
4.2a to current; may affect earlier versions
If you connect a gadget to the Square Wave A (1 sec on/off) tag in the Data Simulator device, the gadget may not behave as expected. For example, if you connect the square wave to an LED gadget, the LED will not turn on when you run your project.
