KB89160
Published: December 23, 2020
Focus on Edit Variable Dialog is Lost
PACCONTROLPRO (PAC Control Professional)
10.0a to R10.3c
R10.3d
If you are using a keyboard helper (for example, a third party app that rapidly makes repetitive keystrokes changes to a UI), you may lose focus on the Edit Variable dialog.
Use an automatic method to convert the idb.txt into a manual tag list.
