KB89156
Published: August 21, 2020
Older PAC Control or OptoControl Strategies with mistic I/O points are incorrect in newer PAC Control
PAC Control Professional
R10.3a
R10.3b
If you open an OptoControl strategy with mistic I/O points in PAC Control R10.3a, PAC Control does not convert the mistic I/O points correctly. In PAC Control Debug mode, mistic points will not have the correct module part number listed on the IO Unit "scanning" dialog. The module ID may also be omitted completely.
Open the strategy in PAC Control R10.2 or earlier.
