KB89137
Published: February 22, 2021
PAC Controller HTTP Status Return Code Incorrect
Firmware for:
- SNAP-PAC-S2, SNAP-PAC-S2-W
- SNAP-PAC-R1, SNAP-PAC-R1-FM, SNAP-PAC-R1-W, SNAP-PAC-R1-B
Version R10.3b to R10.4b
R10.4c
In PAC Control, when using the command HTTP GET, the HTTP code returned is the actual code multiplied by 65536. For example, if the return code is 13107200, the actual code is 13107200 divided by 65536, or 200.
Divide the return result by 65536 to find the actual response code.
