KB89094
Published: July 20, 2020
Can't Add Supported Versions of BACNet Server to CODESYS Application
Opto 22 Library Package For CODESYS Development System
2.0.0.0
2.0.0.1
GRV-EPIC-PR1 firmware version 2.0.0 added support for CODESYS BACNet SL versions 1.2.1.0 to 1.5.1.0. However, the Opto 22 Library Package for CODESYS Development System version 2.0.0.0, which supports GRV-EPIC-PR1 firmware version 2.0.0, does not allow you to add any BACnet SL version other than 1.2.1.0.
In your CODESYS application, add CODESYS BACnet SL version 1.2.1.0.
