KB89079
Published: July 22, 2020
Unpredictable Behavior With CODESYS Controller
Firmware for GRV-EPIC-PR1
Version 1.3.0 to 2.0.1
2.0.2
If you enable the CODESYS Controller, you may see either of the following behaviors:
- Unpredictable behavior.
- Services may become unreachable.
To check if you have enabled the CODESYS Controller, log into your GRV-EPIC-PR1 with a user ID that has system-level privileges. Then from the
groov Manage Home page, click Controller > CODESYS Controller. The Status will show whether it is enabled or disabled.
