KB89054
Published: September 2, 2020
The OPC UA tag browser allows you to assign unsupported tags to gadgets
groov View running on:
- GROOV-AT1, GROOV-AT1-SNAP
- GRV-EPIC-PR1
4.2a to current
The OPC UA tag browser allows you to assign unsupported tags to gadgets. If you assign a tag with an unsupported data type (for example, dates or times) to a gadget, you may run into problems when you run your groov View project; for example, the gadget may not respond or it may prevent page navigation. You may see this more prevalently in tags from CODESYS applications.
If you added this type of gadget to your groov View project and your project is not responding in groov View:
- Switch to Build mode.
- When groov View indicates there is a problem (for example, it displays an error message and the Build mode window looks blank), refresh the browser. groov View reloads Build mode.
- Select and delete the gadget, then save the pages immediately (click File > Save All Changes). You may have to refresh one more time to completely clear the issue.
