KB89047
Published: June 9, 2020
Reconfiguring a DI Channel May Clear the Feature Parameter
Firmware for GRV-R7-MM1001-10
All versions prior to 2.0.1
2.0.1
If you previously configured a discrete input with a feature (counter, frequency, etc.), then you later reconfigure that discrete input without changing the signal type, it will erroneously clear the feature configuration.
The only types of changes that should trigger setting a feature's MMP value to zero are changing the channel type or feature.
