KB89044
Published: August 31, 2020
groov View reports "This gadget does not have a properly configured tag" for some OPC UA array tags
- GROOV-AT1, GROOV-AT1-SNAP
- GRV-EPIC-PR1
4.2a to current
If you connect an OPC UA tag that uses an array data type with an unspecified array length to a gadget, groov View may report that the gadget does not have a properly configured tag.
If you can edit the tag before associating it to a gadget, make sure that the tag has a length specified in the OPC UA server. If an array tag without a length has already been associated with a gadget, update the tag's definition:
- From Build Mode in groov View, click Configure Devices & Tags.
- Select the OPC UA server that has the array tag.
- Click Update Static Tags.
