KB89035
Published: July 22, 2020
Configuration Changes Not Sent to RIO I/O
Firmware for GRV-EPIC-PR1
All versions prior to 2.0.2
2.0.2
If a RIO I/O unit is included in a PAC Control strategy, the groov EPIC processor does not send the configurations to the RIO unless the groov EPIC processor is restarted or a new strategy is downloaded. This includes manually enabling the communication from PAC Control Debug mode. It also includes the use of the following PAC Control commands:
  • Enable Communication to I/O Unit
  • Enable Communication to All I/O Units
  • Enable I/O Unit Causing Current Error
Opto 22 recommends you cycle power to the GRV-EPIC-PR1.
